Contributor I
Timeout in clearpass
Hi
I have a strange issue with some users having trouble when starting their machines (cold boot), they have to wait 15 to 30 seconds before the wireless is active, sone users log on before the connection is there, and is loggd in cached. If wireless is switched off/on no issue
In the investigation of this issue i see some Timeout 5 to 10 every day, i se no pattern in it, and i have tried to point to other AD and DNS.
[main SessId R00000ea8-01-599ac1b5] ERROR RadiusServer.Radius - reqst_clean_list: Deleting request sessid - R00000ea8-01-599ac1b5, state - ANYAYQCsALhV0AAAplJ9u0C7eghTLvJcek0Xlg=
[main SessId R00000ea8-01-599ac1b5] ERROR RadiusServer.Radius - reqst_clean_list: Packet 108:244:88:4851B75E43E0 recv 1503314357.433801 - resp 1503314357.443851
[main SessId R00000ea8-01-599ac1b5] ERROR RadiusServer.Radius - reqst_clean_list: Packet 111:410:236:4851B75E43E0 recv 1503314357.452483 - resp 1503314357.453606
[main SessId R00000ea8-01-599ac1b5] INFO RadiusServer.Radius - rlm_policy: Starting Policy Evaluation.
I have no clue where to look for this error ?
I am on CPPM 6.6.5
Is there any that have some hints ?
I have included a log
Regards Erik Loeth
Re: Timeout in clearpass
Which EAP method are you using?
How are the supplicants being managed?
Tim Cappalli | Aruba Security
Contributor I
EAP-PEAP
Aprox 2500 clients over the day
Regards Erik Loeth
Contributor I
Noboddy has any ide where to look ?
Regards Erik Loeth
Is your EAP server certificate publicly or privately signed?
Contributor I
Thanks for replying
Clients is getting a policity from AD, and the certificate is public (not wildcard)
I will verify that the eap cert i a public to morrow.
Regards
Erik Loeth
Contributor I
Hi
Yes it is a public cert, from godaddy
Regards Erik Loeth.
Contributor I
Hi
After a TAC case the issue was a timeout on the client side, client not responding.
The issue is now investigated, it seems that a securetty software is slow to start.
Regards Erik Loeth
