FXE
Traffic Passing Mgmt and Data Port
Hi Experts,
Do you have a list of traffic types that SHOULD be passing via MGMT port and DATA port?
For example, MGMT for cluster comms and DATA port RADIUS traffic.
Thanks.
Re: Traffic Passing Mgmt and Data Port
Please take a look at the service routing technote:
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Method/attachment/Default.aspx?EntryId=14011
Thank you
Victor Fabian
Lead Mobility Architect @WEI
As Victor mentioned, take a look at the TechNote. For most common scenarios, using a single interface is recommended.
Tim Cappalli | Aruba Security
