When I disable lower transmission rates from 1 to 11, I get temporary authentication error but client eventually connects on the second try or after a few seconds, but when the lower transmission rates are enabled, there is no authenticaion error.
I had set the minimum transmission rate to 12 when I was getting the brief authentication error. Is there a reason why that happens when lower transmission rates are disabled?
