Contributor II
Two SSID's using 802.1x authentication with same Radius server
How would I implement below secenario.
Two SSID's (example SSID 1 & SSID 2), both uses same RADIUS server (Microsft NPS), We want user A can connect only to SSID 1 (for example), and USER B can connect only to SSID 2. Is this a RADIUS only configuration or set up any policy in the controller?
Re: Two SSID's using 802.1x authentication with same Radius server
The true problem is that NPS cannot inspect additional radius attributes that Aruba sends that indicates what SSID a Radius Authentication comes from.  The Aruba controller sends the following additional parameters:
Aruba-Essid-Name
Aruba-Location-Id
 Aruba-AP-Group
 Aruba-User-Vlan
To get around this when using NPS, you can:
- Create 2 Radius Server Groups
- Duplicate your first Radius Server (exact ip address, key etc)
- For each individual Radius server, edit the NAS-ID field to any text you want to differentiate one from the other
- Use the NAS-ID as an additional rule on the NPS server...
Does this make sense?
Contributor II
Thanks Joseph, you are a champion.
Hi Joseph,
In my case, any group linked to NPS authenticates.
Even I put the NAS-ID and NAS-IP controller.
Best regards!!!
Hi Colin ,
We have the exact requirement and tried this option with wireless policies on NPS side to match a particluar LDAP group and NAS ID as well. However we have another policy below to match all users on the domain but no NAS ID , what we observe here is that if the first policy check fails , then users are getting connected using the policy that matches the domain user group with out NAS ID . Is this an expected behavior  ?
Ranjith
Trusted Contributor I
i think you can configure your NPS to require a NAS ID
or create two services, one with NAS ID one and one with NAS ID two so it matches for sure.
Contributor I
This feature may not have been available in the older versions, but you can now include the ESSID in the called-station Id.  In the radius server settings at the bottom you can enable include_ssid and set the delimiter (I don't think it matters what it is). Then in NAP under the Conditions tab add the Called-Station ID and just put in the SSID here.  It does let you use regex here too, but I found just putting the full SSID worked fine. Then set up one policy with one SSID and another with the other SSID, and use different windows groups to dictate which users can connect to each one.
