Occasional Contributor I
UPN authentication with clearpass and active directory
I have Clearpass authenticating iPhones and Androids.  I need to pass the UPN authentication from Clearpass to Active Directory to have Clearpass make a decision.  Both phones authenticate via a certificate.
My Android phones authenticate with the AD SAM username. EX ncci/ncdlt. The iPhones try to authenticate with the UPN. EX daniel_tominovich@ncci.com.  The Androids work and the iPhones do not.
How do I get Clearpass to pass the UPN on to AD for authentication?
Re: UPN authentication with clearpass and active directory
Under the authentication tab (at the bottom), try stripping the domain using the "user:@" syntax.
Tim Cappalli | Aruba Security
I tried that and it had no effect on the authentication.
Changing from this:
(&(objectClass=user)(sAMAccountName=%{Authentication:Username}))
to this:
(|(&(objectClass=user)(sAMAccountName=%{Authentication:Username}))(&(objectClass=user)(userPrincipalName=%{Authentication:Username})))
was the fix.
