Unable to authenticate when using Huawei's AP
guys..I'm using Huawei AP 5030DN, currently have 2 SSID:
- 802.1x
- Captive portal
802.1x works fine but the captive portal can't be authenticate, i've tried various setting in web login under vendor setting, still the same. the result after i insert my credential would be required parameter unavailable, or..it will stuck at please wait, loading (no logs in access tracker)
i'm not sure what to put in address details ..
can u guys help me..
