Contributor II
Upload content for use in captive portal
When I try to upload new content to use in our customized captive portal I run into the following error.
System has low free memory and/or low free disk space. Please delete unwanted files by accessing WebUI Maintenance > File > Delete Files, reload the controller to recover free memory and try uploading the image again. If it fails again, try other upgrade options.
This error is pretty self-explanatory.. you'd say :)
What command can I use to determine wether dispace and/or memory is the issue?
Re: Upload content for use in captive portal
Please try the following commands.
(3600) #show memory
Memory (Kb):
total: 1541408, used: 285068, free: 1256340
(3600) #show storage
Filesystem Size Used Available Use% Mounted on
none 300.0M 3.2M 296.8M 1% /tmp
/dev/hda3 392.7M 111.7M 260.7M 30% /flash
(3600) # dir
Vinod Kumaar AVM ACMX, ACDX
Principal Network Engineer
Customer Advocacy | Aruba Networks Inc.
Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the bottom right hand corner of the post.
Contributor II
(ZMARUBA01) #show memory
Memory (Kb): total: 354376, used: 297832, free: 56544
(ZMARUBA01) #show storage
none                    300.0M      3.8M    296.2M   1% /tmp
/dev/hda3               392.7M    145.6M    226.8M  39% /flash
(ZMARUBA01) #
Seems to be enough mem/storage.. right?
Contributor II
Monday mornin' bump
- What controller platform is this?
- What verson of ArubaOS?
- How big is the content you are trying to upload?
Can you try typing "tar crash" at the commandline and copying off and deleting the crash.tar file and trying again?
Can you type "dir" to see if you have any file that you might not be using there?
Contributor II
Creating and deleting the crash tar did the trick, tnx.
Contributor II
Seems to be a temp fix.
Same problem again, cant upload any custom content (html files)..
Any ideas?
Contributor II
Bump
Please open a support case to get to the bottom of this.  I can say that I have not seen your issue, but others might have.
hey,
please enveekaa have you found any solution to this issue, i got the same probleme with a 7030 controller
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
