Contributor I
Users connect when cert is revoked
 I`m implementing an onboard solution. Since I need to create the certs manually, I install them on the PC but when revoke que cert on the clearpass, the users can still get into the networks, but it does not happen when use the quickconnect.
Re: Users connect when cert is revoked
Are you using OCSP Validation ?
Thank you
Victor Fabian
Lead Mobility Architect
Are you using the same CA for the manual devices and the Onboarded devices?
Tim Cappalli | Aruba Security
Contributor I
Hi
I'm not using ocsp validation.
And using the same CA for both.. the idea is just to generate manual certs.
You need to use OCSP. That is how the authentication process validates the
validity of the certificate.
Contributor I
You mean, I need to use tjis on the auth method? Or activate that on the onboard CA?
[EAP TLS With OCSP Enabled] should work.
Contributor I
I set the [EAP TLS With OCSP Enabled] on the service but now no users can connect even when the cert is not revoked.
Please provide an access tracker dashboard details export.
Contributor I
Attach 2 files..
