Using AD Attributes to authenticate users at one location vs another
I have a deployment where I would like to use a specific AD Attribute to authenticate users at one particular location if their attribute matches a particular number.
Therefore all users having this attribute along with this number are allowed to authenticate at location A and nowhere else.
User's at location B will have the same attribute but with a different number.
The number can be a store #, dealer #, something that identifies which location they belong to.
Not too sure how to go about configuring this. We are using EAP-PEAP MSCHAPv2 to authenticate the users. I assume somewhere in the enforcement profile i will be validating against the attribute whether it is exists and checking the value and then how do i go about linking that number to the location?
The other thing is that if the attribute contains a specific word let's say 'allow', then this user can authenticate at all the locations.
I know this is possible but not too sure how to implement right now.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Re: Using AD Attributes to authenticate users at one location vs another
Create a custom device attribute and add the same value to the NAD entries. So if location A was value 1, then add a custom attribute the NADs in that location with a value of 1.
Then you can just write a two rule policy. One that checks if those two values match. Another that looks for the all value.
Tim
Tim Cappalli | Aruba Security
thanks now is that method scalable? I have about 200+ sites..
I'll give it a shot.
ACDX #420 | ACCA
Yes because you already have the NADs defined, you're just adding a single value. Your enforcement policy can be 2 rules total and handle all of those sites.
Tim
Frequent Contributor II
In our environment, I added the location attribute for all of the devices to take preference over the closer Regional Clearpass. This is a very useful option.
k, thanks.
Let me give this a shot and post back once I do or run into issues
ACDX #420 | ACCA
I believe I got it to work.
Took me a while to fully understand what you were saying Tim, it is not that obvious when you are looking at Clearpass from a n00b point of view but I figured it out.
With these rules, if I modify the NAD to have "national" and my user has 12345, I am denied access, if I change my NAD to 12345, my user can connect.
This is blowing my mind for such as simple item.
Thanks all.
ACDX #420 | ACCA
Your rule would reference the variable for the entry in the device list, not a static value. That allows it to be completely dynamic for each store with only 2 rules.
Tim
I just need to make it wildcard based so that I don't have to type in the value manually.
Each location will have a different attribute value so checking against a static value is not going to work for me
ACDX #420 | ACCA
Ya trying to make it work currently, no success.
I have it doing something like this
(Authorization: AD (no proxy):physicalDeliveryOfficeName EQUALS %{physicalDeliveryOfficeName})
 AND  (Device:dealer EQUALS %{dealer})
 AND  (Device:dealer EQUALS national)
Not working yet…will continue to troubleshoot.
ACDX #420 | ACCA
