Super Contributor I
Using CPPM To Manage Controller Login #mhc
In this tutorial I’ll show you how to create a ClearPass service for login to the Aruba controller.  A member of Active Directory group Engineer will be assigned Aruba mgmt. “root” role, while a member of AD group Guest-Provisioning will be assigned Aruba mgmt. “guest-provisioning” role.
To make it easy to follow the process of building this ClearPass service, I also include a flow chart.
If you found my post helpful, please give kudos!
~Trinh Nguyen~
Boys Town
