Contributor II
Using Customer's Browser IP address to map roles and apply application enforcement profiles
I would like to use the ip address of a customer's web browser to determine which Guest Operator Profile to use.
For example I only want to allow students connecting to the Guest regsistration login from the dormitory wired subnet(s) to have a specific Guest Operator Profile privileges.
Thanks.
-Neil
Neil Johnson
Re: Using Customer's Browser IP address to map roles and apply application enforcement profiles
I don't believe this is possible since the client's IP is not available in policy during a CPG login.
Tim Cappalli | Aruba Security
Contributor II
Thanks! I'll test it in the lab.
-Neil
Neil Johnson
Contributor II
Yes, I tried it in our lab and it doesn't work. The Client-Src-IP is always returned as 127.0.0.1
Neil Johnson
