Valued Contributor I
Using attribute generated in 1 clearpass filter in another filter
Is its possible to use an attributte generated in one clearpass filter in another filter? e.g I've got a filter that returns the name of a column in a mysql database table. I then want to extract the contents of that table column using some other selection criteria. Normally I'd use a stored procedure that prepares an sql statement  ( select <column name> ..... ) and then feed it the apropriate parameters to get a result, but can't use stored procedures in clearpass 6.4.4 :-((
Rgds
Alex
Super Contributor II
Re: Using attribute generated in 1 clearpass filter in another filter
I have been working on a similar requirement however wasn't able to get this going but i did find a way to achieve the same functionality.
You can use nested SELECT queries to retrieve the initial attribute and pass it back to the second select query.
eg
SELECT tag_value as owner FROM tips_endpoints_attr_view
WHERE tag_name = 'Owner' AND mac_address = (select mac_address from tips_endpoints_attr_view WHERE tag_name = 'UDID' and tag_value = '%{Authentication:Username}')
