Valued Contributor I
Using clearpass to manage Mobility Controller ACL lists
Might be a silly question ...
I'm currently passing a Filter-Id attribute back to our mobility controllers and using it to apply a particular policy to a user session. This does of course mean that we have to create the ACL lists that are used on the controllers which we seem t ohave tpo do by hand either via the GUI or CLI
Is there any way of clearpass managing an ACL list contents ? e.g. something like its ability to  pass ACL rules down to a provision switch in an Access Accept packet ?
Rgds
Alex
Re: Using clearpass to manage Mobility Controller ACL lists
http://community.arubanetworks.com/t5/Controller-Based-WLANs/Downloading-an-undefined-role-from-CPPM-to-Controller/ta-p/243661
In addition, if you are using clearpass, you should return the Aruba-User-Role radius attribute or the Aruba-User-Vlan attribute from clearpass, instead of using filter-id and then having to write a server derivation rule on the controller.   Using those attributes will automatically assign the role and/or vlan without having to have a corresponding server derivation rule looking for a filter-id attribute.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
well everything seemed to have worked apart from the Aruba-User-Role bit.
looking at Firewall policies /[System Role|Policies] I can see the stuff I sent back
 Clearpass is sending back
adius:Aruba:Aruba-CPPM-Roletest_cppm_role_enforcement-3110-4
ip access-list session super_user_role
    any any any permit log
user-role cppmrole
Radius:Aruba:Aruba-User-Role
cppmrole
where super_user_role is the default "allowall" with logging
However, Firewall policies / User Role doesn;t have a cppmrole entry. Should I be sending back the System Role test_cppm_role_enforcement-3110-4 ?
Rgds
alex
You won't see them in your config. Downloadable roles are added and destroyed as they're used and released.
Tim Cappalli | Aruba Security
When configuring  a session based  the acl list in CPPM, you don't seem to be able to distinguish between ipv6 and ipv4, whereas on the controller you can
Not important at the moment as we're just dipping our toes into the ipv6 pond but might be in the future
A
