Frequent Contributor I
VIA VPN with ClearPass
In scenario when ClearPass is used for authentication of VIA clients based on PAP/MSCHAP as authentication method we run into situation that if VIA is loaded on non-corporate machine they can join network if good user AD credentails are used.
Is there any way of allowing only corporate machines on the network through CPPM service? Thanks.
NesaM
NesaM --ACMP, ACCP--
Re: VIA VPN with ClearPass
Do your corporate devices have machine certificates?
Tim Cappalli | Aruba Security
Not at the moment, though it is planned for near future. Until that happens, is there anything that can be done to guarantee non non-corporate ones can join? Thanks.
NesaM
You can leverage the Domain Pre-Connect feature in VIA to perform a machine authentication.
http://community.arubanetworks.com/t5/Controller-Based-WLANs/What-is-Domain-Pre-connect-in-VIA-and-how-does-it-work/ta-p/184550
Thanks Tim, appreciated.
Customer has made a decision to move down the certificate based VIA route, so we will have to deploy that option now.
NesaM
