MVP
Virtual ip settings
I was under the impression that clearpass redundancy would have to be set at the authenticator level (switches/controllers)?
I.e. I would have to add the publisher and the subscriber nodes as 2 seperate radius servers in my authenticating server group in my wlan controllers.
Now I see however a "virtual ip settings" option in clearpass 6.1 (not sure if it was there in earlier versions).
Is this indeed like a vrrp where I enter both publisher and its subscriber with the result that my server group only needs the virtual-ip configured?
Any advantages of this over configuring 2 auth servers in your authenticators?
Koen (ACMX #351 | ACDX #547 | ACCP)
Re: Virtual ip settings
The virtual IP in 6.1 does indeed provide similar functionality to VRRP. You would point your devices to the single virtual IP. I think the benefits would depend on your network. If you have hundreds of switches and controllers, it's much easier to add a single RADIUS server config.
Tim Cappalli | Aruba Security
Contributor II
Can a vip be assigned to the data and management interfaces?
I only ask as i get an error when trying to assign a vip to the data interfaces after adding a vip to the mgmt interfaces.
cheers
I think your issue is that you don't have both IP addresses on the same segment
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor II
I know :smileyembarrassed:
bit of a typo missed the 1 got so excited to test this new feature that I missed the typo.
MVP
Using Virtual IP interfaces in a ClearPass Cluster:
http://www.youtube.com/watch?v=0kk8HSoPiZQ
High availability for a ClearPass Cluster
http://www.youtube.com/watch?v=dHLRU_kYsUs
