Contributor I
Vlan Pooling with Clearpass
I am trying to get all of my BYOD devices onto a pool of vlans.  I found the "Aruba-User-Vlan" attribute in the enforcement profile, however that only allows me to set one specific vlan number.  On the controller I can assign multiple vlans on a virtual ap profile, and that works well, so is there away to do it with clearpass?  Can I assign a virtual ap profile via clearpass enforcement profile?  I have looked but i can not find any option that will work the way I am trying to get it.
Re: Vlan Pooling with Clearpass
You cannot send back an attribute that will do pooling.  You could have a larger VLAN that those devices are assigned to and return that, if you need capacity.  Or, you can have CPPM just send back an accept and have those devices end up in the Pool from the Virtual AP and have your OTHER devices assigned to the single VLAN from a radius attribute.
Contributor I
Thanks cjoseph,  I had kind of figured as much, so I had started creating large vlans.  That will work perfectly for my needs.  Your reverse idea is clever also!  Thanks.
Try sending VSA from ClearPass Radius:Aruba   Aruba-Named-Vlan  <vlan-pool-name>. Tried with AOS 6.4.0.3 and ClearPass 6.x and it worked.
