Frequent Contributor II
Web auth with aruba controller
Is there a way to use a coa based web portal on clearpass guest using aruba controller?
I'm trying to set-up on-guard with anonymous login. (I.e how it was in 6.2).
Re: Web auth with aruba controller
You can do it with creating a Web Login that has anonymous login/OnGuard. See screen shots
screenshot_12 Mar. 06 23.39.gifscreenshot_02 Mar. 06 23.35.gifscreenshot_03 Mar. 06 23.35.gifscreenshot_04 Mar. 06 23.35.gifscreenshot_05 Mar. 06 23.36.gifscreenshot_06 Mar. 06 23.36.gifscreenshot_07 Mar. 06 23.36.gif
Thank You,
Troy
Exactly how I have it. But it appears that the php code looses the username and password after the scan is complete. So it never actually submits.
Are you seeing any errors in access tracker?
Thank You,
Troy
No I am not. On the client it says. "* Username: Required field unavailable"
You need to hit the page with a redirect. If you are trying it from just hitting the test button it will not work. CPPM will get the mac address and tie it to the anonymous account. You need to make sure you have to check mark to auto generate the account..
The error you are getting is on the guest side from an account not being created when you hit the logon button.
Thank You,
Troy
Hi sdr53,
I had the same issue with you. I never made it successful before.
Did you sovle this issue?
Could you share it to us?
Hi tarnold,
I tried to follow your way what you post.
But I never made it successful.
Any idea?
Thanks.
I did it poor mans way and just redirected to google after 10seconds using php redirect. So the user reads the error and then all the sudden they are at google and carry on with their day. Our policy lets them to the internet even if they fail the onguard solution. But I need to change it to use a CPPM webauth solution. That might be your best route.
There are alot of pieces of this,
1. so what errors are you seeing,
2. are you seeing auth requests hitting the CPPM side,
3. any errors in the event viewer in guest.
4. Can you do a regular 802.1x or MAC auth to CPPM from your controller?
Thank You,
Troy
