What MDM solutions does HPE Aruba ClearPass support ? MobileIron, Airwatch, ....
HPE Ericsson account team are working on an opportunity where a MDM solution is required.   Team is looking into Airwatch MDM , however we wonder what MDM solutions are supported by ClearPass, so that it can turn into an end to end system
Re: What MDM solutions does HPE Aruba ClearPass support ? MobileIron, Airwatch, ....
AirWatch, MobileIron, BES, JAMF, SOTI, XenMobile, SAP Afaria, MaaS 360
Tim Cappalli | Aruba Security
Airwatch is supported, yes, but other servers can be supported with XML-API, etc:
http://www.arubanetworks.com/techdocs/ClearPass/Aruba_CPPMOnlineHelp/index.htm#CPPM_UserGuide/Admin/ContextServerActions.htm%3FTocPath%3DAdministration%7CEndpoint%2520Context%2520Servers%7C_____1
Moderator
Here is a link to the ClearPass EMM/MDM Integration TechNote, this should help you as well.
Tech Note: ClearPass Enterprise Mobility Management Integration V5
Best Regards
-d
ClearPass Product Manager
