What are the right ports for CPPM to AD
I observed the following using packet captures:
udp53
icmp-echoreq
udp389
tcp389
Tcp445
tcp139
tcp88
udp88
tcp 636
Other posts have this;
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Clearpass-cluster-traffic-firewall/td-p/59360
They are different...and different makes firewall people squirm.
Also...they are very hot on removing the 389, 139, etc ports.    Any comments on removing ports after the domain join and switch to SLDAP?
MVP
Re: What are the right ports for CPPM to AD
Thanks Victor.
Anyone willing to comment on tightening those ports after the join and switch to SLDAP?
