Frequent Contributor I
What data rates should be enabled?
What datarates should be enabled or disabled under SSID profile? I have disabled lower datarates under 11g transmit rates but users can still connect to 1mbps. My understanding is that a user connection will be dropped should a user move in an area with low coverage and AP will not support lower datarates?
Please refer to attach image.
Need your guidance in this regard.
Farzan
MVP
Re: What data rates should be enabled?
Remove both the basic and transmit rates to disable those lower speeds.
Koen (ACMX #351 | ACDX #547 | ACCP)
