What do I give up using IAP (VC) based WLAN vs Controller based WLAN when using CPPM?
Frequent Contributor II
Re: What do I give up using IAP (VC) based WLAN vs Controller based WLAN when using CPPM?
not that much I think. IAP's are a bit more limited in fine tuning your wireless environment.
you can still assign vlan or role with IAP's.
I would say very little to nothing.  What is your application?
Colin Joseph
Aruba Customer Engineering
