Contributor I
What is battery DB?
Hi all,
Just received an update from support saying that 1 of my CPPM battery DB is getting clogged and this causing the server memory utilization is high and end up I have to restart all the services to reduce the congestion.
But can i know what is battery db? can i have any info on this? or any supporting document so i can understand further?
Re: What is battery DB?
Battery is the internal name for the "multi-master-cache", which is a memory resident DB we use on a single-node and across a clusters of nodes.
Best Regards
ClearPass Product Manager
