Contributor II
What is the different between Terminated on Controller and Not Terminated on Controller?
Hi guys,
I saw the option on Cotroller 's GUI, but I still don't understand the point of terminated on controller.
Could some one explain about it, please?
Re: What is the different between Terminated on Controller and Not Terminated on Controller?
Contributor II
Thanks a lot, so the whole point of terminated on controller is that the role of the controller is played.
If we enable the termination on controller, then the controller would act like a authenticator,
If we disenable the termination on controller, then the controller just simply sends the packets to the Radius Server,  the Radius Server would act like a authenticator and a authentication server at the same time.
Is that right?
The controller is still the authenticator.
Termination:
Controller >> [LDAP/S] >> AD/LDAP
TLS tunnel: Client >> Controller
Not terminated:
Controller >> [RADIUS] >> RADIUS server > AD/LDAP
TLS tunnel: Client >> RADIUS server
You should definitely terminate on a RADIUS server.
Tim Cappalli | Aruba Security
Contributor II
Thanks again, it looks like I have to learn about the TLS first.
When using a tunneled EAP protocol like EAP-PEAP or EAP-TTLS, a secure tunnel is built between the client and RADIUS server (or controller if using termination) to exchange network credentials.
