Contributor II
What level of integration is available between ClearPass and Good Technology's MDM solution?
I notice that Good Technology's MDM is not a solution specifically covered (at least, if it is, not within the 6.4 User Guide) but there is an option to Add Generic HTTP Endpoint Context Server within the chapter dealing with MDM integration. Not sure if that's any help really...? What options to interoperate with Good???
Moderator
Re: What level of integration is available between ClearPass and Good Technology's MDM solution?
You can't use CPPM Exchange as this is a outbound REStful framework, we can't use it capture input data, parse this and then write it to the endpoint DB.
However, Good runs on top of MS SQL... this can be accessed via a standard ODBC connection. So you can define this DB as a SQL type auth-source and grab data... my inside knowledge of an issue I've heard about is that the DB stores the MAC addresses in differing standards which can make this I understand (no hands on here myself) a little challenging.
Best Regards
-d
ClearPass Product Manager
Contributor II
Hi dannyjump and thanks very much for your reply.
I wasn't 100% sure I understood the second part of your first sentence    "we can't use it capture [sic] input data, parse this and then write it to the endpoint DB."    Though I think i understood the general gist;  CPPM Exchange seems to be a tool to allow Clearpass to provide additional information to the offboard context system, to allow it to do it's own job, whereas I'm looking to do the opposite;  use info from the offboard system (Good, in this case) to allow Clearpass to make more informed policy decisions   (?)   Hence you pointing out that an ODBC lookup on Good, for the MAC details it stores seems ideal   (if it works!?!?)
Thanks again....
ND
Hi Danny,
Any news/change about Good integration on ClearPass ?
ACMP 6.4 / ACMX #107 / ACCP 6.5
Moderator
We have limited interest but I’m currently looking at justifying the creation of a BES/Good integration via CPPM extensions. We have a handful of customer that have requested it recently or have asked for it in a RFP/PoC.
What is your level of interest and what version of BES are your running/moving-to?
Best Regards
-d
dannyjump wrote:
Hi Danny,
I ask because a customer have this EMM solution and i want to known the integration of Good
Moderator
Can you please share the to djump@hpe.com
customer details
the version of BES currently deployed
if not deployed their timeline
What use-cases do they want out of the integration
is CPPM deployed
Best Regards
-d
