When creating a batch of users is there a way to change or remove entirely the role prefix?
[ Edited ]
Basically we would prefer if there is no mention of role or no prefix at all. We know we can't name each user individually since it is a batch but we want it to at least not have a prefix.
Re: When creating a batch of users is there a way to change or remove entirely the role prefix?
The system does not default to prefixed-based random usernames.  Someone must have configured this.  Check the create_multi form under Customization > Forms & Views, and make sure random_username_method has an appropriate value. If you search the inline Help for random_username_method you should get sufficient detail.  Here are some of the common options:
     'nwa_digits_password' => NwaText(1122, 'Random digits'),
     'nwa_letters_password' => NwaText(1126, 'Random letters'),
     'nwa_lettersdigits_password' => NwaText(1119, 'Random letters and digits'),
     'nwa_picture_password' => NwaText(6903, 'Format picture'),
     'nwa_sequence' => NwaText(8001, 'Sequential numbering'),
