When using VRRP , witch address do I use in Microsoft NPS ?
Hi All,
when i configure my two controllers with VRRP , witch address do I use to communicate with the radius server.
can I use only the VRRP ?
Regards
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: When using VRRP , witch address do I use in Microsoft NPS ?
Use each controller real IP address
And define it using the following command
ip radius nas ip
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
