Occasional Contributor I
Which ClearPass Modules do I need for BYOD and Guestaccess ?
I am looking for a solution to provide BYOD access and Guest access.
- BYOD access should work via Certificates (e.g. EAP-TLS), company employees should do that via registration e.g. webauth with MS-AD credentials. After that the BYOD should get a certificate with the CN of the company-AD-username and an EAP-TLS konfiguration for authentication to the ClearPass authentication server.
- Guest access should work via web-authentication, a ticket should be given via a sponsor, who generates the guest-ticket. After that the Guestuser can connect to the wireless network and gets an http-redirekt to the guest authentication portal.
- I don't need any device fingerprinting, because BYOD and Guest will be on the same SSID and will get the same access to the internet.
What Clearpass systems are needed for that ?
I thought following:
ClearPassPolicy Manager (Base System)
- ClearPassOnboard for BYOD Access (SW-Module in PolicyManager)
- ClearPassGuest for GuestAccess (SW-Module in PolicyManager)
Best Regards
Alois
Re: Which ClearPass Modules do I need for BYOD and Guestaccess ?
aheilmaier wrote:
Best Regards
Alois
You are correct about the requirements.  ClearPassOnboard is a SW-Module in the ClearPass Guest Server, though.  ClearPass Guest is also a Software Module in the ClearPass Guest Server.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
