Frequent Contributor II
Which interface clearpass will use to send CoA ?
I have configure Data port, management port and VIP IP in clearpass.
Now if I send a CoA req from Clearpass to Controller which IP the clearpass will use to send that CoA ?
rana
MVP
Re: Which interface clearpass will use to send CoA ?
Data interface
B -eth0
Management
(gigabit Ethernet) Provides access for cluster administration and appliance maintenance via
web access, CLI, or internal cluster communications. Configuration required.
C -eth1
Data (gigabit Ethernet) Provides point of contact for RADIUS, TACACS+, Web Authentication and
other data-plane requests. Configuration optional. If not configured, requests redirected to the
management port.
Regards
John Solberg
-ACMX #316 :: ACCP :: ACSA
Aruba Partner Ambassador
Intelecom Group - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Moderator
Can I suggest a read of my 'Service Routing TechNote'... find it here.... CPPM Service Routing TechNote - V3
Best Regards
-d
ClearPass Product Manager
