Valued Contributor I
Which network interface do CoA requests come out of
I've got a cluster of CPPM servers, I'm using both network interfaces so I've got a management lan and a data lan. An F5 load balances client requests across the data lan interfaces of each of our secondary  servers.
I've a question about how a CoA request gets out of the cluster. If I'm logged onto the master publisher and I send a CoA request to terminate a session, what clustered box does it come out of? Do CoA requests all come out of the master publisher? Does it come out of the cluster member that  serviced the  initial auth request?
Other reason for asking is on our comware switches you have to define the ip/key associated with the box sending the CoA and thats either going to be the master or all members of the cluster.
Rgds
Alex
Re: Which network interface do CoA requests come out of
It should be sourced from the server that handled the authentication request.
You should add all of your servers for dynamic authorization.
Tim Cappalli | Aruba Security
and if your servers have 2 network interfaces, a managment one and a data one that all the auths come in via?
Which interface do the CoA requests come out of?
A
The Data Port
Thank you
Victor Fabian
Lead Mobility Architect @WEI
