Frequent Contributor II
Why certificate required for windows devices not for Android and ios
We have configured TLS+802.1x authentication for our wireless client. (CPPM TLS certificate will be use for auth)
We have configured below services on CPPM
My query is - Why we need to push/manually install CPPM certificate on windows devices.
On Android devices clearpass quickconnect auto install. On IOS devices we need not to install client or push certificate.
Is it possible to auto install CPPM certificate on windows devices
Thank You...
Re: Why certificate required for windows devices not for Android and ios
Not sure I'm understanding. If you're using EAP-TLS, the certificate has to be installed on the device manually or through an EMM provider.
Tim Cappalli | Aruba Security
