Why should I set up vlan interface IP ?
  • 1.  Why should I set up vlan interface IP ?
    Posted Apr 14, 2016 04:57 AM
    Hi Guys,
    I set up a Captive portal profile today, but the portal couldn't pop up.
    After I've checked everything, I found I didn't set up a vlan interface for the user's VLAN.
    But I have a MAS as my default route, why should I need a vlan interface IP?
    Please someone tell me why.
    Thanks.
  • 2.  RE: Why should I set up vlan interface IP ?
    Posted Apr 14, 2016 05:05 AM
    An IP is required for dst-nat which is used to redirect the user.
  • 3.  RE: Why should I set up vlan interface IP ?
    Posted Apr 14, 2016 05:19 AM
    And why the user can't use the controller ip to do the dst-nat?
  • 4.  RE: Why should I set up vlan interface IP ?
    Posted Apr 14, 2016 05:21 AM
    Because the controller IP is not in their datapath.
  • 5.  RE: Why should I set up vlan interface IP ?
    Posted Apr 14, 2016 05:37 AM
    Could you tell a little bit more about it?
    From the Policy, we can see this:
    358: user any  6  0-65535  80-80   d1f90,0000 f80021:permit dnat
    Anyone from the User-table tried to reach any IP with a tcp port 80, then hit this policy.
    From the WebUi, it shows dst-nat 8081.
    Does this dst-nat 8081 mean the vlan interface IP only?
  • 6.  RE: Why should I set up vlan interface IP ?
    Posted Apr 14, 2016 05:41 AM
    I'm not sure what you're asking. Traffic destined for port 80 and 443 are dnat'ed to the controller's IP on the user's subnet and ports 8081 or 8082.
  • 7.  RE: Why should I set up vlan interface IP ?
    Posted Mar 24, 2017 07:47 PM
    This kinda helps me understand why a controller hostsed captive portal config needs an IP on the client VLAN; however, would the same be true if we were redirecting to an external clearpass appliance?
    Couldn't I simply have an ACL rule that allows http & https traffic to the clearpass IP?
  • 8.  RE: Why should I set up vlan interface IP ?
    Posted Mar 24, 2017 07:49 PM
    Yes, you need an IP address when doing any kind of redirect.
