Wildcard Certificate with Captive portal
Import comercial wildcard certificate to the aruba controller, but when I try to connect captive portal SSID, Why does it show that certificate untrust (captive-portal.example.com)?
Re: Wildcard Certificate with Captive portal
Are you trying to access an HTTPS site?
Tim Cappalli | Aruba Security
No. I try to access http site, it do redirect to captive-portal.example.com to take authentication.
Wildcard from Digicert
Does your captive portal server have a valid cert? Is the captive portal server whitelisted in your pre-auth captive portal profile?
The name for a wildcard should be captiveportal-login.<name of your wildcard> instead of captive-portal.
See: https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-does-Aruba-Controller-work-with-wild-card-certificate-for/ta-p/203199
