Frequent Contributor II
Windows 8.1 have and issue connecting to Aruba controller and android work normal?
I am connecting my clearpass and controller to use 802.1x now android work normal but windwos 8.1 can not connect at all tried all thing no luck I have read something related to the PMK but they also said the new updates soolved it and now Im using version 6.4.2.5 (ArubaOS) so what may cause this and also how to disbale PMKID?
Re: Windows 8.1 have and issue connecting to Aruba controller and android work normal?
What does the auth-tracebuf show?
Security logs?
Do you see any request on your RADIUS server?
Are you using a public or privately signed CA?
Tim
Tim Cappalli | Aruba Security
yes ona ccess tracker gives yellow 9EAP transaction not completed
Can you provide answers to the other questions?
Tim
This is the show auth-trace
Aug  8 10:43:42  eap-id-resp           ->  ec:0e:c4:3e:ca:65  00:24:6c:80:9d:70                1    14   employee1
Aug  8 10:43:42  rad-req               ->  ec:0e:c4:3e:ca:65  00:24:6c:80:9d:70                204  201
Aug  8 10:43:47  dot1x-timeout          *  ec:0e:c4:3e:ca:65  00:24:6c:80:9d:70                1    3    server timeout
Aug  8 10:43:47  dot1x-timeout          *  ec:0e:c4:3e:ca:65  00:24:6c:80:9d:70                2    2    station timeout
Aug  8 10:43:47  eap-id-req            <-  ec:0e:c4:3e:ca:65  00:24:6c:80:9d:70                2    5
Aug  8 10:43:48  station-down           *  ec:0e:c4:3e:ca:65  00:24:6c:80:9d:70                -    -
and for the certificate I'm using the self signed one
If the self signed cert installed on the clients?
Tim
