Wired Security - Per-port vs Per-user tunneled node
Hi...
I have to implement a wired security, but I'm confused ( =s ) regarding this topic.
In my case I should authenticate users that are connected to Aruba OS switches.
The MC autheticates the users and assigns user roles.
But....
What is the differents between per-port and per-user tunneled node?
Which one should I use?
Thanks in advance.
Regards
Re: Wired Security - Per-port vs Per-user tunneled node
Did you take a look at the ClearPass Solution Guide for Wired Policy Enforcement? It covers it in great depth.
Tim Cappalli | Aruba Security
Thank you so much....
This a great document.
Resolved!!!
Cheers
