Wired enforcement for Access point (tagged and untagged vlan)
Hi all,
I would like to enforce on my switch AOS 2930 the specific port config which will be used when I'll plug Aruba APs:
Untagged vlan: Vlan for Access Points
Tagged vlanS: all my users vlans (Corporate, Guest, etc.)
User trafic won't be tunneled to Wireless controler.
How can I do that?
Shall I configure Aruba User-role? In that case, I don't see how, in a specific role I would configure several tagged vlans...
OR
Shall I use classic vlan enforcement in that scenario?
I guess it's the second method but I'll be sure of that
Thanks for your help
Fred
Re: Wired enforcement for Access point (tagged and untagged vlan)
Aruba campus APs should simply sit in a user subnet, just like any other client device. There is no need tag any VLANs.
Take a look at the ClearPass Solution Guide for Wired Policy Enforcement for configuration examples.
Tim Cappalli | Aruba Security
Hi Tim,
your solution doesnt work for us.
What we want to do:
When an AP is plugged to our AOS 2930F switches, CPPM must enforce:
- vlan AP untagged
- vlan Corporate tagged
- vlan Guest tagged
- vlan Printer tagged
- vlan blabla tagged
Even if you place your AP in another vlan, I don't see how to enforce a tagged vlan via CPPM (an moreover, how to enforce several tagged vlan)
I read wired guide and didn't find a solution too
Kind regards,
Fred
You said the APs are tunneling to a controller. There should be no tagged VLANs on a campus AP.
No,
I said:  User trafic won't be tunneled to Wireless controler.
It'll be locally switched. That's why I need tag
Fred
OK, sorry misread. You cannot use RADIUS assigned user roles then. You’d have to use device-profiles with LLDP to map the user role.
OK,
Do you have any doc or example of how to do this?
That 'll be great
Fred
I don’t sorry. Probably a better question for the switching group.
I used this guide:
https://community.arubanetworks.com/t5/Wired-Networks/Returning-multiple-tagged-VLANS-and-untagged-VLAN-from-ClearPass/ta-p/413955
Tested with CPPM 6.7.2 and 2930M on 16.05 and 2920 on 16.05
I used MAC auth with profiling. The AP profile gets all the additional tagged VLANs
Frequent Contributor I
Have you checked device profile?
Please check below if it helps:
http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/RA/16-01/webhelp/content/ch10.html
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
