Wireless Authentication Reference Sheet
Hello everyone,
as someone who likes cheat sheets and reference sheets and since I work with authentication daily, I created my personnal reference sheet about wireless authentication. It includes, what I judge to be important things when working with auth and also content that is hard to memorize. Hopefully, it can help you guys too memorizing it and save some time when sticked near your desk.
I'm attaching the high res PDF and also PNG files. Bare with me, I'm not a graphic designer ^_^
Enjoy,
ACMP, ACCP, BCNE
MVP
Re: Wireless Authentication Reference Sheet
Love this! Thanks man!
Sean Rynearson
Contributor I
Thanks sir!
Occasional Contributor I
Neat, thank you !
Here is another useful OpenSSL command that I used to convert a Wildcard certificate in .p12 to a .pem, accepted by IAP internal captive portal server :
openssl pkcs12 -in 'CertificateName.p12' -out 'CertificateName.pem' -nodes
Did you make that in Visio or another application? Interested in making similar charts for data flow for our controllers and dependencies. Looks great! Thank you for this! :-)
Thank you :) Yes ! All in Visio
ACMP, ACCP, BCNE
