Occasional Contributor I
Wireless access request from selfservice portal
Hi, my problem is the mail that the sponsor get, the accept link is not correkt.
Right now it is: https://srv277/guest/guest_register_confirm.php?gsr_id=guest_register&token=fs22r-qi9cs-qhzvw-rdgam-zpdaf
and i need it to be
https://clearpass.mycompany.com/guest/guest_register_confirm.php?gsr_id=guest_register&token=fs22r-qi9cs-qhzvw-rdgam-zpdaf
where can i change this?
Re: Wireless access request from selfservice portal
Is that your ClearPass FQDN ?
Can you reach your ClearPass server using ClearPass.YourCompany.com by doing a nslookup ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
yes i can reach it by using clearpass.yourcompany.com
You should try giving your CP server a FQDN for the hostname under Server Configuration.
Is there just one server or multiples with a VIP?
Tim Cappalli | Aruba Security
i only have one server
thanx i try.
Aruba
Renaming CPPM should do it, but if you can't for some reason you can copy the print template that is being used for the confirmation email to have the full URL of your choice as well.
You can copy the template under Configuration --> Print Templates; make your changes; and then reference this new Print Template within the self-registration page configuration.
For example:
A visitor has requested access naming you as the sponsor.  Please <a href="{'https://<Name or IP of your choice>/guest/guest_register_confirm.php'|NwaGetAppUrl:false:$u.require_auth}?{if $u.source}gsr_id={$u.source|rawurlencode}&{/if}token={$u.register_token|rawurlencode}" target="_blank">click here</a> to confirm or reject the request.
{else}
Do you <a href="{'https://<Name or IP of your choice>/guest/guest_register_confirm.php'|NwaGetAppUrl:false:$u.require_auth}?{if $u.source}gsr_id={$u.source|rawurlencode}&{/if}token={$u.register_token|rawurlencode}&confirm=1" target="_blank">confirm</a>
or <a href="{'https://<Name or IP of your choice>/guest/guest_register_confirm.php'|NwaGetAppUrl:false:$u.require_auth}?{if $u.source}gsr_id={$u.source|rawurlencode}&{/if}token={$u.register_token|rawurlencode}&confirm=0" target="_blank">reject</a> the request.
AMFX | ACCX | ACDX | ACMX
