Guest Blogger
Within Airwave a Method to Distinguish Device Disconnect and Access Denial Types
Within Airwave, is it possible to distinguish and determine the following:
  • device that is denied access to an SSID
  • device that disconnects from an SSID
  • device that is denied access to a network
  • device that disconnects from a network
  • device that cannot authenticate
  • device that deauthenticate for any reason
Some of these scenarios may be one in the same. My overall question relates to where in Airwave can I determine the status of a device. I would also ask the same question (and corresponding scenarios) for ClearPass and accounts within ClearPass.
Aruba
Re: Within Airwave a Method to Distinguish Device Disconnect and Access Denial Types
From the Home screen, there is an Alert summary box.  In there, you can click on RADIUS auth issues.  It will give you a table like this:
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Guest Blogger
Thanks Seth. I have a discussion with an administrator that has access a production AirWave server. There should be plenty of RADIUS authentication issues on that server.
Guest Blogger
For devices that authenticate with CPPM or another RADIUS server, this works. However, for devices that authenticate with a controller-based landing page server or Linux-based landing page server, I did not see those devices in the window that you showed. For devices that authenticate with a passphrase, I do not see those devices either. Sorry that I did not clarify before, how do I answer the questions that I asked before for devices that do not authenticate with RADIUS?
