Contributor I
advertising and submit
We have a ClearPass guestportal with advertising on the guest receipt, and we'll guest useres to click the links og the advertising but the users are not logged in yet. Is there a way where we can implement submit/login to the hyperlinks on the advertising?
Trusted Contributor I
Re: advertising and submit
what exatly do you mean with submit / login exactly? should they login without anything by clicking the link?
or do you want to allow some sites before login? you could looked at walled garden for the latest one.
