Contributor II
airwave failover and master console config
hi,,
i have trying to depoly airwave with failover, and master consloe, i have checked user guide for my airwave 7.7 and in the steps he says on go to home page and  look for watched amp,
where is the watched amp tab or link???
how to configure watched amp, and is the watched amp the second airwave?
thanks
Re: airwave failover and master console config
you need a proper license for the fail over at that point you can configure the watched amp. the same for master console
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
