Contributor II
airwave gui not responding
My airwave gui does not respond. IP address resultis in blank browser page. I can CLI into the system. Any helpful commands or suggestions?
Re: airwave gui not responding
when you CLI in do you see a bunch of processes running?
you can type amp_enable now and see if the processes start.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Did you change the cert. if so you need to start pound on reboot.
service pound start
Thank You,
Troy
