block mobile devices connecting to certain SSID
Hi
is there anyway we could block IOS and android devices specifically connecting to a particular SSID. i have a 3600 aruba controller and it had latest version of software 6.4.3.7
thanks
Karthik
Re: block mobile devices connecting to certain SSID
Do you have ClearPass?
What authentication method is in use?
Sent from Nine<>
Tim Cappalli | Aruba Security
The specific wireless is setup of computer based testing and teachers in the classroom will connect the laptops to this specific wireless. For easy access right now is open
It would be easier to enable authenticaton via 802.1x.  An Open SSID does not leave you many security options that cannot be circumvented.
Colin Joseph
Aruba Customer Engineering
Frequent Contributor I
Is device descrimination  possible with a controller based SSID?
I know ClearPass can but hoping to achieve this without migrating the SSID to ClearPass.
