can AP-220-MNT-W2 work with kensington security slot
If we choose to use mounting AP-220-MNT-W2 , will it block the kensington security slot at ap 215 ?
Re: can AP-220-MNT-W2 work with kensington security slot
The AP-220-MNT-W2 does cover the kensington lock hole (used the AP-220-MNT-W2W, white version to get a better picture):
It is about where the red rectangle is...
However if you tilt the AP, you can see the hole:
So depending on your lock, it may fit, or may not...
Probably, you will need to test it if you are in doubt...This mount is closed, and can be locked with a security screw, so if mounted properly it can be made very difficult to remove the AP.
Regards, Herman
