Frequent Contributor II
can i do vlan enfocemnt for each hotspot plan?
Can I do vlan enforcement for each hotspot plane example
Free access enforce ro vlan 10
Daily access enforce vlan 20
Weekly vlan 50
Is it applicable and how?
Re: can i do vlan enfocemnt for each hotspot plan?
You can choose the hotspot plan id in the enforcement profile,
for example
this would be the condition
(GuestUser:hotspot_plan_name  EQUALS  Free Access)
then enforce whatever you want on it,
