Trusted Contributor I
cant drop clearpass subscriber due to virtual IP settings
got a clearpass cluster (version 6.3.4) of two nodes, a publisher and subscriber. the publisher has failed and no standby publisher is configured. now i would like to drop the subscriber to make it publisher, but im stuck in a catch 22 i believe.
when i click drop subscriber it says "Drop Subscriber is not permitted. Server is part of Virtual IP Settings"
but when i try to remove the virtual ip settings it says "Modifications are not supported on Subscriber node; please use Publisher node."
also i would like to leave the virtual ip untouched as removing that can cause an interuption.
i found the CLI command cluster make-publisher is that my only option or is there something else to do?
Re: cant drop clearpass subscriber due to virtual IP settings
Yes, you should promote to publisher. You should always have an active publisher.
Tim Cappalli | Aruba Security
ok and via the CLI is the only way to go?
little note for aruba, update the documentation to also say the -f flag is possible for the cluster make-publisher command.
In this instance, yes.
In 6.4 the VIP restriction is removed so you don't have to have both servers defined.
I will have to test and see if it will help in your instance.
Thank You,
Troy
thanks guys, that is enough information for now.
