Regular Contributor I
captive portal redirection aruba welcomeCaptive portal redirection to URL... but not Apple...
Hi Forum,
I am not sure how widely used this is, but we use the php script on CPG to redirect users to the originally requested URL.
http://community.arubanetworks.com/aruba/attachments/aruba/aaa-nac-guest-access-byod/10457/1/Amigopod%20Technote%20-%20URL%20Persistence%20with%20Aruba.pdf
However, now everything is under great scrutiny - and when apple captive portal assistant springs up it still works, except it produces a "success" page.  I know this is what IOS looks for, but I think the above workaround confuses IOS and makes it show the page not receive the page and get rid of the portal.
It's untidy - any ideas how to get rid of this?  That is use the redirection, but make it Apple Captive Portal compliant?
Thanks in advance.
Nik
Regular Contributor II
Re: captive portal redirection aruba welcomeCaptive portal redirection to URL... but not Apple...
This is because the Apple Captive Network Assistant (CNA) is triggering the redirect and CNA is requesting captive.apple.com. You can disable the ability for the CNA to launch on both the Aruba controller and Clearpass. This would stop this happening but would mean the end users would need to manually open a browser app as opposed to it popping up automatically.
David
ACDX #98 | ACMP | ACCP
