Regular Contributor I
clearpass capacity
Hi, quick question, if i need clearpass for 1K end devices, is it possible to use 2 servers of CP-HW-500 instead of 1 server of CP-HW-5K?
if it possible, what is the downside of using 2 CP-HW-500 instead of 1 CP-HW-5K?
Ricky E. Lee
CWNA | ACMP | ACCP
Re: clearpass capacity
Quick answer is yes, but you'll want to ensure your NADs are load balancing requests to the two boxes.
I would recommend reaching out to your ClearPass partner as there are many considerations here.
Tim Cappalli | Aruba Security
