last person joined: 11 hours ago
clearpass configuration for Wired 802.1X authentication with Alcatel switch
  • 1.  clearpass configuration for Wired 802.1X authentication with Alcatel switch
    Posted Aug 17, 2017 09:15 AM
    I am now working on implementing aruba clear pass with alcaltel switch.
    earlier we had done all the configs using free radius soft.
    I need to keep my old radius server as authentication source . but want to pass the authentication control from free radius to aruba clear pass.
    I have refreed to this below metioned video-->
    https://www.youtube.com/watch?v=GWgfHCkDHMM
    I beleive the above mentioned youtube tutorial was dedicated for  dynamic vlan scenario. but i need the configuration for static vlan scenario.
    I am attching my configurations done in authentication server...
    Authentications server IP:135.249.47.251
                                         key:alcatel123
    o/p of client.conf file in radius server
    [root@pc-012 raddb]# cat clients.conf
    client 135.249.41.194{
    secret = alcatel123
    login = polclient1
    shortname = private-network-1
    o/p of supplicant.conf file
    auth_period = 150
    network_list = all
    identity = poluser3
    default_netname = default
    allow_types = all
    eap-md5 {
    username = poluser3
    password = "1234567"
    o/p of users file from radius server
    [root@pc-012 raddb]# pwd
    /usr/local/etc/raddb
    [root@pc-012 raddb]# !cat
    cat users
    # Fall-Through = Yes
    #####Radius Auth CLI Users
    poluser1 Cleartext-Password := "password1!"
    SUPERUSER Cleartext-Password := "POL#150"
    # On no match, the user is denied access.
    peersheik Cleartext-Password := "1234567"
    Service-Type = Framed-User,
    Framed-IP-Address = 135.249.41.194,
    Framed-IP-Netmask = 255.255.255.0,
    Framed-MTU = 1500,
    # Session-Timeout = 40
    polclient1 Cleartext-Password := "1234567"
    Framed-MTU = 1500,
    configurations done in switch-(authentication client) : 135.249.41.194
    configure system security radius auth-server RADAuthServ1 router-instance base ip-address 135.249.47.251 secret plain:alcatel123 timeout-limit 5
    configure system security radius acc-server RADAccServ1 router-instance base ip-address 135.249.47.251 secret plain:alcatel123
    configure system security radius dyn-auth-client RADAuthServ1 router-instance base ip-address 135.249.47.251 secret plain:alcatel123
    configure system security radius policy RADPol23 nas-id MyNASID nas-ip-address 135.249.41.194
    configure system security radius policy RADPol23 servers 2 auth-server name:RADAuthServ1 auth-router-inst base priority 162 acc-server name:RADAccServ1
    configure system security domain alcatel.com authenticator radius:RADPol23
    configure system security conn-profile Profile_1 version 1 domain-name alcatel.com reject-inv-domain
    configure system security conn-policy conn-profile-name Profile_1
    configure system security pae port-access
     clear pass server details:
    Managemntport Ip address->135.249.43.111/24
    Data/External Port->
  • 2.  RE: clearpass configuration for Wired 802.1X authentication with Alcatel switch
    Posted Aug 17, 2017 09:22 AM
    Did you take a look at this solution guide? It doesn't directly cover Alcatel switches, but the ClearPass side is likely similar to some of the other vendors.
    http://community.arubanetworks.com/t5/Security/ClearPass-Solution-Guide-Wired-Policy-Enforcement/td-p/298161
  • 3.  RE: clearpass configuration for Wired 802.1X authentication with Alcatel switch
    Posted Aug 17, 2017 09:42 AM
    i will look into the doc and will try to do all possible configurations
