clearpass onguard process start
Ciao,
do you know if there's possibility to send posture before that the user login on workstation ?
In a 802.1x machine authentication implementation this can help to give network access before user login.
Thank,
Re: clearpass onguard process start
No. Onguard can only launch after a user logs in. You could give "temp" access to devices that have previously passed a health check to allow them to login. You would use a role that allows domain controller communication.
Tim
Tim Cappalli | Aruba Security
null
