Contributor I
clearpass policy manager - network device issue
I can not authenticate a client using CPM. The network access device is IAP-205. i can see only following information on event viewer.
Source Radius
Level WARN
Category Authentication
Action Unknow
Decription: Ignoring request from unknow client ...
I do not understand why the issue is occured.
Re: clearpass policy manager - network device issue
Mathew0306,
Did you add the IAP's ip address as a radius client under Configuration> Network> Devices?
The Event Viewer should say the ip address that the radius traffic is coming from.  In IAP, also you have the option of enabling "Dynamic Radius Proxy" where all of the radius traffic of an IAP cluster comes from the same ip address:  http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#UG_files/Authentication/Dynamic Proxy RADIUS.htm
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Valued Contributor II
HI,
As per the information provided, the RADIUS client is not configured properly. the best solution is,configure VC IP address and enable "Dynamic RADIUS proxy" option from Advanced options of System menu.
For your ref :
Please feel free if the issue is not resolved.
Cheers,
Venu Puduchery,
Contributor I
Your advice does not resolve me issue. I had configured the network device before I created this topic.
In my network works only one IAP, so I assumed that setting the VC and Radius Proxy would not help m but I have done it. Unfortunatelly I can see the same warn message.
Could anybody help me?
Mateusz
What ip address does the event viewer say the traffic is coming from?
Set the VC address and dynamic radius proxy, so that you can narrow your issue.
the event should show you the IP of the NAS that is trying to connect
Thank You,
Troy
Contributor I
I have set the VC and Radius Proxy, but It does not resolve this issue.
In the event viewer I can see exactly the same IP address which I configured as VC and in the Network -> Device tab.
Mathew
mathew0306,
Please feel free to open a TAC case, then.
